My headlights will not come on. All other lights work, park, tail, interior, etc. Looking at the wiring diagrams, I suspected the headlight dimmer switch. Swapped out a spare, but still no headlights.
I pulled the wires from the dimmer switch, yellow, green and tan. Green goes to high beam, tan to low beam. Yellow is the power source from the headlight manual switch. If I hotwire the green or tan from the battery, the lights work.
Voltage at the yellow wire is12 plus with the manual switch turned on. But, if I connect tne yellow to eitner the tan or green, basically turning headlights on, the voltage at the yellow wire goes toward zero.
I suspect the circuit breaker in the manual headlight switch. I have a spare, but this is on my 59 body on the 95 SS chassis. I have the headlight switch installed in the 59 stock position, and it will require a major dash disassembly to get to it.
Before I tear my dash apart, I was wondering if anyone else has experienced this, and do you think I am on the right track?
