Most likely the blower motor resistor. Easy fix. Part from Rockauto or local.
Get your head in the passengers side foot space and look up by thw wheel well (after you remove the vanity panel). Plug and play.
HTH.
If they look the same, and the plug fits, they are probably the same. You can look on Rock Auto's website and check to see if the part numbers are the same.
