·I just broke a wheel sensor. I was extremely careful with it and was going no where. I tried all angles to get the sensor out (yes the bolt is removed) and I just had to give it some more force so I ended up cracking the plastic housing. Even after I broke it, I beat the living daylights out of it and I still couldn't hardly get it out and finally after I beat it to dust it was removed from the spindle.
So, I haven't done the other side yet, and I am afraid to see how much one of these puppies is going to cost. I am sure it can't be cheap sincel none of the local part stores have it. SO that means either junkyard or dealer, which it will probably be the dealer since I will probably destroy the junk yard ones too.
What is the trick to remove the sensor? ANYONE? THis sucks.
Brian
Brian
