Whats up guys, i seem to have a fringed rubber piece which connects to the what i believe is the radiator. Can someone please tell me what this is? Im assuming its not difficult replace?
Can someone please tell me what this is? Im assuming its not difficult to replace?
Oil lines go to a driver-side radiator side tank on nearly every civilian LT1 sedan and wagon that is not a 9C1 / 1A2.Are the '94s the ones where the oil cooler lines go to the radiator or is that just on F-bodies?
Yes to the above, asap. When it fails it'll make a mess. That is one ancient radiator, by the way.(Try replacing that cap with a longer hose and a tightly fit bolt.
This is what I would recommend. The cheapie caps you can find at auto parts stores I assume are more-so for vacuum type lines. And over time they get brittle, not good for a coolant cap. I’ve used one like pictured above in the past and [[knocks on wood]] never a problem.
I second this, both my 96' and my dad's 95' have that nipple on the radiator, blocked off with a cheap rubber cap exactly like OP's.My aftermarket radiator (received earlier this year) has the nipple provision pictured there. I just capped it off.
It may not be super old but rather an aftermarket radiator.
I see thats there’s different diameters. Any suggestions on the size needed for my radiator?My aftermarket radiator (received earlier this year) has the nipple provision pictured there. I just capped it off.
My OST brand radiator from RockAuto needed (i believe) a 3/8” cap.I see thats there’s different diameters. Any suggestions on the size needed for my radiator?
Thank you, i’ll post update after installMy OST brand radiator from RockAuto needed (i believe) a 3/8” cap.
EDIT: Looking back, it looks like I used the same HPS Performance brand that 95wagon linked.
