i need some help folks im intrested in getting a pair of heads im not ready to stroke my motor for another year or two i just wanted some after market heads, i already have a cam (comp cam 07-503-8)what would be a good set of heads to go with them.
1. You should never buy a cam until AFTER you've gotten your heads spec'ed.......
2. But since you already have a cam, contact each of the following linked companies, tell them what you want out of your engine, and see what kind of head set-up they recommend.
http://www.eportworks.com/LT1LE2.htm
http://www.advancedinduction.com/AiContact.html
3. You do realize that with the 503 cam, you'll need at least 3.42 gears and a 2600+ stall TC for optimal performance in a B-body....right
KW
Another good source for heads on par with the two that KW mentioned:
Mike Harris at B-Body Performance: 937-231-1979
That's where mine will come from ;)
Originally posted by The Bolt-On Terror:
What Pat said :cool: ....
The only reason I didn't suggest Mike is because I hate to tell newbies to 'look' for someone......
But hey, Pat has Mike's number.....and I agree that he is a great option ;) .
Now.....if Mike would only setup a web page
......hint
KW
