J
Cant stop inside tire wear. Alignment is straight, moog everything, and bad left front bearings changed. Could there be something in the rear causing this?
i'd be willing to say, most likely not, did you do the alingment, or no? if you had a shop do it, you might want to take it somewhere else and have them check, have you checked tire pressure?
U
JimmieSS, gotta suspect alignment, especially
camber... Are you lowered at all?
ok you need to find a good alignemnt shop in your area one better than firestone i just dont trust those guys. look in the phone book you will find a good alignment shop and i bet your problems will hopefully be solved or at least someone more quailfied than firestone techs will look at your ride and get it set right.
U
Jimmie, just got out of work, sorry. With the
lower springs you will probably need offset
cross-shafts on the upper arms to allow enough
shims to effectively adjust camber. I did!
I'm guessing the alignment shop may have settled
for what they could get.
