Hi, I'm a newbie here. Need a little help. Looking for a picture of a wagon fuel sender assembly. I'm replacing the fuel pump in the Beastwagon and the return tube which holds the pump/sender assembly appears bent and I cant seem to correctly orient the assembly so it will seat into the tank. Not sure if I bent it removing the tank or what. The two diagrams in the factory manual are not consistent. One shows the tube is completely straight, the other shows two nintey degree bends.
Thanks...
Thanks...
