·First, three facts. My Impala hates me, Murphy lives with me, and AGR can't seem to ship me anything that freaking works despite their premium price.
Now on to the details. Long but please hang with me because I really need help.
I replaced my power steering pump (third time) with an AGR pump 13 months ago because the car would intermittanly be very hard to turn at an idle. The AGR helped some, but the problem still happened occasionally. Figured it was time to replace the 150K mile steering box but had to save up for that one. Replaced the box with an AGR unit about a month ago. Didn't help the problem. We've also noticed since installing the new AGR Steering Box that the steering pressure isn't consistant. When you turn the wheel you can feel the pressure change while you turn it and it is consistantly harder to turn left than right. I've also replaced the belt, replaced the tensioner, installed an Meziere water pump, checked to be sure the pully on the pump wasn't slipping and that the crank wasn't slipping.
Called AGR, the tech guy there said he had NO idea what could be going on, but agreed to replace the AGR pump with another one for a "reduced" price. We were assuming the brand new AGR Box was good so the problem had to be the ,barely year old, pump.
Installed the new pump today. As usual I went through the complete purge/bleed ritual (put the car on stands, turn the weel back and forth fifty gazillion times, etc. etc.) and am only using Royal Purple PS fluid per AGR's Recommendation. Now NONE of the old symptoms have gone away, but we added a new one! This pump groans anytime you turn the wheel at an idle. I bled the system again and no bubbles showed-up. Checked all fitting. Replace the o-ring on every fitting that was opened on the pump and box replacements. No sign of leakage. The fluid doesn't rise when I turn the motor off. The ONLY thing in the system I haven't replaced are the lines. I've inspected those and see nothing wrong, crimped, etc. and no sign of air in the system. I checked for pully slipage again. I replaced the belt again and it didn't help.
Unless anyone has any insight on this, the only conclusion I can come up with is that everyting AGR has sent me to date was defective out of the box. Any other ideas would be greatly appreciated because AGR is EXTREMELY slow shipping things. This second pump they had sitting on the shelf and it took another phone call and a week just to get it out the door to me. My daughter would like to have her car back and right now I'm afraid to let her drive it until I sort this out.
I need suggestions please!!!
