Hi,
I'm looking for some tips on what I might be doing wrong on changing the body bushings on a 1995 Impala.
I have purchased the energy suspention body bushing kit. I have changed all the bushings EXCEPT #4 upper between the doors.
I am jacking up the body with a 2x4 to the point that the frame is starting to lift off the jackstands. All the bolts are removed from the one side and the other side is loose.
I am not able to get the #4 (between the doors) bushing out. I have pryed with a crow bar which pulls the frame down a tiny bit (because it is now off the jack stands), but I still do not have enough room to pull the bushing and sleeve out.
The bushing is in very good condition, so im guessing that may be why i can't get it out. I am entertaining the idea of cutting/ torching the bushing out, but i am afraid I might not get the new one .
I've attached a picture of the bushing as far as i can get it. The floor bumps out on both sides and I can't rotate it out.
How important is the #4 bushing? If I get all the other, im thinking it should be pretty good? It does bother me to get all but one. Probly will loose sleep over it...
