1996 ss impala a/c compressor bad wait till summer to fix. then thermostat goes bad, overheats replace. fans comes on and stay on. replace compressor and all fuses, relays, senors. a/c won't come on without jumping. told pcm reads high temp, re flash. doesn't work. HELP
Fans staying on could be a bad CTS or a bad connection or broken wire.
A/C not running without jumping should be low on refrigerant.
Does it still over heat? If so, water pump may be bad.
I just had a customer bring me a car which kept overheating within a minute.
Took front cover off water pump... All impeller blades had rusted off.
New water pump and good as new.
Just something to check.
Nab
CTS=coolant temp sensor. On front of water pump
If you are not original owner///maybe PO wired fans direct to circumvent instead of repairing something else…..like the fan relays.
Are there 2 fan relays in the underhood fuse block on passenger fender?
