Question: I recently swapped out my HIDs as the ones I had went bad. I replaced the whole kit and bulbs. Maybe I'm losing my mind but the current low beams look like the old high beams and the current high beams look like the old low beams.
I thought if I unplugged the battery and hit the high low switch once and then plugged the battery back in it might work but it didn't.
Only other thing I could think of would be if I reversed the high low wires but from what I remember those are shaped so you can't plug them in backwards. I'll check this tomorrow in the daylight.
Unless anyone has any suggestions, I might just take out the high beam indicator bulb on the dash...
