I had a very similar problem when I installed the 58mm BBK trottle body in my car when the stroker went in. Look at the attached photo to see what was going on with mine.
The top plate/bracket in the photo is connected to the cruise control cable. The plate/bracket behind it has the throttle stop for the idle position and the throttle cable attached. The post/rivet that comes through these plates is connected to the throttle blades. This post/rivet is mechanically "peened over" to clamp the two plates to the post. On mine, the mechanical attachment just was not tight enough to hold the plates "fixed" together. When I stomped on the throttle to WOT, the blades would open, and the force of the cable would pull the plate around a few degrees of rotation. When returned to "idle" , there was 1/8" to 1/16" of air gap between the throotle stop on the plate and the adjustment screw, meaning that the throttle blades were still slightly open resulting in a fast idle. I would have to rotate the bracket to the correct idle position by hand.
I solved the problem by tack welding the plates and rivet together as shown in the photo. No more fast idle after WOT. Problem solved.
