D
93 caprice with 170K miles
It doesn't appear to be an engine thing. Doesn't happen at idle if I rev the motor, only when it is moving, whether I am hitting the gas pedal or not.
Seems to come from the left front.
Is one of the struts shot? Ball joints? What could it be? Performance is not affected.
R
Your car does not use struts, so you can count that out, but i would check to be sure everything is greased, then check bushing wear, and all joints, ie ball joints, tie rod ends, sway bar, just check in that area where you hear the noise, let us know.
