Do i need to get my computer flash if i install a 2600 stall convertor?? have lt4 hot cam kit, headers, have had comp tuned for the idle and a few other things already. is 2600 a good stall??
Hey bud! What part of MD are you from? As for the tune, yes you do. Car will run but not to its full potential without it, and in the case of the converter, you might enter trans limp home mode.
Chris
Need more stall IMO for an LT4 hot cam. Anyways tuning isn't super needed for a stall, but it can help with idle (motor can surge ), lockup points, how the converter stays locked, and sometimes modifying tables to keep the trans out of limp mode, from "stall wall"
