I finally got a new hood lamp assembly to replace the old one with broken connection and i have no power but good ground at both the hood and trunk lights. Do these share a fuse by chance?
The 91-93 cars use the #1 fuse for the lights, front and rear. I would assume that the 94-96 cars would be almost identical in that respect. It may be controlling a number of other lights, so if the fuse does not fix it, you may have an open in the wiring near a splice.
I only had a couple minutes to mess with it. Fuse #27 was good, replaced it anyways and still no power at the plugs for the hood and trunk lights.
