The horn on my 95 was out at least i thought it was dead. I accidently tapped it while driving and it worked. While it home I pressed the horn button on the wheel nothing, while holding it and hitting the wheel it came on. Is this a problem on our cars?
On my newest white 94 Fleetwood, the horn doesnt work on it either even though the fuse is fine. The horn works because I set off the factory alarm yesterday.
On my wrecked 94 the horn works while parked, but once you drive it works when it wants to work.
E
i have read more than 1 post about horn problems,my 94 caprice,horn would beep when you moved tilt wheel,not the 96 i am sitting on now.
My Buicks horn is touchy. you blow on it, and it will sound. Sounds to me like the switches are junk on these cars.
E
I had a problem with my horn too. But it was my horns... I guess all those years of my car being a limo got to the horns...
