Im finally getting a start on my 96 DGGM and trying to find out sum info. I have to take the car for emissions so i need it to be able to pass a OBDII scan. It does not have to pass a sniffer test.First off i not trying to go and have 11 sec B-Body just a good strong weekend car. I will probably go with a 383. So far i have acquired a set of complete LT-4 heads with rollers and a set of clear image budget headers. Im trying to find out will those headers match up to the factorys cat set up? How big of a cam can you go and still be able to keep all the light off in the dash. I dont plan on running the cats all the time just when needed for the test. I will prob run 3.73s in the car. I want the car to run good and be able to in and take a 500 mile trip with no issues. All info is appreciated.
My understanding is with a good tuner, anything will pass a plug-in only test. Just tune out certain CELs like rear O2s or any other emissions you might remove.
Thanks for the input I'm suprised so lil response. Nobodys made good power and still pass emission. I'm just trying to get sum ideas on what I need to do
........First off i not trying to go and have 11 sec B-Body just a good strong weekend car. I will probably go with a 383.........How big of a cam can you go and still be able to keep all the light off in the dash.........
Well......you can go with a damn big cam and "keep all the light off in the dash".....but you might not pass emissions.
Noel (aka "Get Bearings") used a a high lift version of the Comp Cams 503. It was 224/230 duration with lift over .600" (w/1.6 rockers). The LSA was 114* with 4* advance.
It got his 383ci into the mid-12's.......I got the same cam for my SS and hit mid-12's also.
IIRC, Noel passed California emissions.....I later put the cam in my 9C1 and with stock LT4 heads and a mail order tune, passed the sniffer in Georgia.
The cam's lobe numbers were #3192 on the intake and #3194 on the exhaust.
http://www.compcams.com/catalog/230.html
FWIW ;) .
KW
