1 - 12 of 12 Posts
Love them. I run Bilstein shocks with them and like the stance and ride
  • Like
Reactions: KW Baraka
Agreed.
As far as I'm concerned, this is the best 'drop' combination for our cars.
KW
  • Like
Reactions: 1slow96
Agreed.
KW
Agreed! Simply put, it just works. They seem to age well too.
  • Like
Springs raise,and lower. Shocks simply dampen spring forces..
Looks more like the rear. Are they both indexed correctly? The top pigtails should be point straight to the left. Not sure how much it affects the height, but should be installed correct either way.
Had some success leveling rear by jacking rear halfway so that springs can be rotated with some effort. Rotate "high" side looking for least resistance. Then rotate "low" side looking for the most resistance. If unsatisfied, try swapping springs right to left, and/or removing isolator from rear end housing on "high" side.
  • Like
Reactions: 91ss
1 - 12 of 12 Posts
