E
I got the complete Hotchkis X-tend kit that has the upper and lower control arms. I've already got the lowers on, but didn't put the uppers on because I was told that they would be too stiff for normal driving/not necessary. They are also adjustable. Any suggestions? I'd like to put them on, but if they'll negatively affect handling/performace I'd rather not.
You think that stiffer arms will screw up handling more than a wrong pinion angle? :confused: I would definitely put the uppers on.
L
You Definately need to put the uppers on..
As stated before, the wrong pinon angle is much worse than the bushing stiffness..
Also, you can do what I did and NOT Install the Polly Bushings on the Axle, I still have the OEM Rubber mounts on the pumpkin and havent had ANY of the afore mentioned binding issues in my Impala.
E
Thanks for the info. They're just sitting in a box here so when I get my 3.73's installed, I'll bring them along as well as my extended yoke and see what they suggest.
