With winter coming it's time to revisit everything properly.
First order of business, height! When I did the initial transmission install the jackstand setup was just brutal, height wasn't enough on top of that it wouldn't allow me to roll under the car properly. On top of that the garage floor is a little bit crooked, pretty much why I was just so hesitant to pull it out again.
So I spent a bit of coin and bought these race ramps. Looks like the clearance should be enough now. A lot less sketchy to get the car this high now since it's a two piece setup.
Next order of business, re-buy the transmission floor jack since the last one I had was faulty.
And also double check pinion angle and what not to make sure the driveshaft and rear-end are not messed up, I don't think it is since the car was driving fine but in the process of doing it right I will leave no stone unturned.
