Well a couple years ago i did an air pump delete. last week i had to replace the front seals so i had to remove wp, opti. Now i got it back together and there are 2 plugs that aren't plugged in. Are these from the AIR pump or did i forget to plug something in? i cant find anywhere they would go. thanks for the help.
should only be one.
Should only be one left as said. Could be intake air temp or coolant temp sensor. If it is your opti or MAF, you won't run. Or maybe fans if you undid that. How many pins and where does it come from?
Check your coolant temp sensor. The plug goes right on the water pump.
Dont see why he would have removed that one to begin with ;)
