1 - 20 of 33 Posts
http://www.compnine.com/vid.php
Interesting .
My car is one of one (big deal ,obscure does not always equate to valuable)
But you can tell how many went to Canada ( 212 )
As for how many 1A2's were built, someone put in their serial.
MAYBE 154 because of the 5361 95 Caprice wagons built, 5207 had the "normal" speedo. That leaves 154 cars with something else.
One would surmise that most if not all would be the certified one.
Unless there was something weird used in the European or middle east cars.
Anyway, interesting sight
- Very cool site, Gerry.
There are a total of 9,147 vehicles matching my year and model (96RMW), but only five others match mine exactly.
For my 94RMW, of the 8,885 matching the year and model, there is only one other that matches the car exactly.
Can't take credit for it, someone else posted it in the misc section.
Seems in most cases the "ultra rare" bit comes from obscure sales codes and such, like I have R6Z which only 32 cars had.
add a few others like that ,really doesn't mean much but skews numbers down.
My total is 1 of 1 but the only "real" low numbers are
212 Canadian options car ( Drl, french labels, child tethers, etc)
238 Two tone
Lots of "less than 1000 options but when you are only dealing with 5361 total, that really isn't really remarkable.
Unless there is an error in the database, it's reporting 638 total 1996 caprice wagons in the database. Cool that only 47 made it to Canada. It's one of 6 with PB1 COVER,WHEEL,15 INCH 15 INCH WHL CVR.
My hopes of finding an extra one are somewhat lessened. Yes, I know there's ONE on ebay for $60 US + shipping.
1/20 08-13-96 Dcm
cross posted from the misc for the wagon folks,.
ran the vin of the canadian 1995 1a2 wagon i had,.says its 1 of 154 1a2's made in 95
Matches
UM6RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE
(UM6)
1,447UQ1RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS
(UQ1)
5,348UQ5SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL EXTENDED RANGE QUARTER MOUNTED 4 SPKR SYS(UQ5)
5,361U11CLUSTER,INSTRUMENT,POLICE CERTIFIED SPEEDOMETER(SEO) SEO POLICE INST CSTR(U11)
154U73ANTENNA,FIXED FIXED ANT(U73)
1,134VK3LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
4,753V03COOLING SYSTEM,EXTRA CAPACITY EXTRA CAPACITY CLG(V03)
1,081V73VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
5,148WU1SWITCH INSTRUMENTATION LIGHTING SHUTOFF INSTRUMENT LIGHTING SHUTOFF SWITCH(WU1)
154YK6Unk.187Z31Unk.209Z49MANDATORY CANADIAN BASE EQUIPMENT MODIFICATIONS(CANADIAN) CANADIAN(Z49)
2121A2VEHICLE-PUBLIC SERVICE SEO PUBLIC SERVICE VEH(1A2)
1541K5TRANSMISSION LOW GEAR BLOCKOUT SEO LOW GEAR BLOCKOUT(1K5)
1541SBPACKAGE-OPTION 02 (1SB)
1521SZPACKAGE OPTION- (1SZ)
2091T1HOSE,RADIATOR & HEATER,SILICONE RUBBER SE0 SILICONE RUBBER HOSE(1T1)
1541Z2Unk.1575AQTIRE ALL-P225/70HR TIRE OPT(5AQ)
3666A2STEERING COLUMN,SEO KEYED SEO KEYED STRG COL(6A2)
1546C7LAMP,PASSENGER DOME SEO PASS DM LP(6C7)
1546E2KEY,ALL LOCKS FOR SINGLE KEY SYSTEM,CODED 37D2 SEO SINGLE SYS KEY(6E2)
106TMCOMPONENT-COMPUTER SELECTED SUSPENSION SUSP(6TM)
3676Y1ORNAMENTATION-EXT MOLDING FRT DR BODY SIDE SEO ORNA(6Y1)
576Y2DELETION-THIRD SEAT 6Y2)
16764ETRIM COMBINATION CLOTH, LT BEIGE (E) (64E)
12364IINTERIOR TRIM,LIGHT BEIGE (64I)
1,2697L9COOLER,HYDRAULIC STEERING OIL SE0 HYD STRG OIL CLR(7L9)
1547P8COOLER,ENGINE OIL AUXILIARY SEO AUX ENG OIL CLR(7P8)
1547TMCOMPONET-COMPUTER SELECTED SUSPENSION SUSP(7TM)
3677Y2LAMP-DOOR OPEN WARNING SEO DR OPEN WRNG(7Y2)
1547Z5FUSE BOX,ADDITIONAL 12 VOLT SEO ADDITIONAL 12V FUSE BOX(7Z5)
13677QMOLDING COLOR,DARK MAPLE RED METALLIC (77Q)
44377UEXTERIOR COLOR,PRIMARY (77U)
EXTERIOR COLOR,PRIMARY,DARK CHERRY METALLIC (77U)
5068RPCOMPONET-COMPUTER SELECTED SUSPENSION SUSP(8RP)
3679RPCOMPONET-COMPUTER SELECTED SUSPENSION SUSP(9RP)
367AA7WINDOW,ELECTRIC OPERATED,QUICK OPENING QUICK OPG ELEC WDO(AA7)
4,933AK5RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
5,361AN4RESTRAINT PROVISIONS,CHILD(CANADIAN) CHILD RST PROVISIONS(AN4)(CANADIAN)
212AP9NET,CONVENIENCE CONVENIENCE NET(AP9)
4,146ARLPLANT CODE-ARLINGTON TX, CPC ARLINGTON,TX ASSEMBLY PLANT(ARL)
5,361AS7SEAT,55-45 FRONT SPLIT FRT SPLIT ST(AS7)
105A75SPRING,SEAT FRONT,CUSHION AND BACK,HEAVY DUTY HVY DUTY FRT ST(A75)
154C49DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
5,144C60AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
5,361DG8MIRROR,BREAKAWAY,FEATURES FOLD & PARK ACCOMMODATION(PAINTED) O/S LH REM CONT,RH DIRECT CONT MIRROR PAINTED(DG8)
MIRROR,O/S LH REM CONT RH DIRECT CONT,FOLDING,PAINTED O/S LH REM CTL,RH DIRECT CTL FLDG,PA(DG8)
455FE9FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
4,852FLTUnk.832F40SUSPENSION,HEAVY DUTY,FRONT AND REAR HVY DUTY SUSP(F40)
5,361GM8AXLE,REAR,2.56 RATIO 2.56R(GM8)
4,245IHEUnk.20JA2BRAKE SYSTEM,HEAVY WEIGHT,DISC,DRUM HVY WT BRK SYS(JA2)
5,361JM4BRAKE SYSTEM,POWER FRONT DISC,REAR DRUM,ANTI-LOCK(CAST IRON) ANTILOCK DISC/DRUM BRK(JM4)
5,361KD1COOLING SYSTEM,TRANSMISSION OIL TRANS OIL CLG(KD1)
3,536KG9GENERATOR,140 AMPERE 140 AMP(KG9)
2,090K05HEATER,ENGINE BLOCK ENG BLK HTR(K05)
HEATER,ENGINE BLOCK(CANADIAN) ENG BLK HTR(K05)(CANADIAN)
332LT1ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
5,361MX0TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDI SING OPTION) A/TRANS(MX0)
TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS(MX0)
5,361M30TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
5,361NA5EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
4,855N10EXHAUST SYSTEM,DUAL D/EXH(N10)
5,361N30STEERING WHEEL(DELUXE) DELUXE STRG WHL(N30)
5,361N40STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40)
5,361N81TIRE,SPARE(FULL SIZE RADIAL) FULL SIZE RADIAL SPA(N81)
TIRE,SPARE(FULL SIZE RADIAL)(EXPORT) FULL SIZE RADIAL SPA(N81)(EXPORT)
4,459N92COVER WHEEL,BOLT ON COVER WHEEL,BOLT ON(N92)
122N97WHEELS,15X7,HEAVY DUTY HVY DUTY WHL(N97)
154R4YUnk.143R7KUnk.419T61LIGHTING,DAYTIME RUNNING DAYTIME RUNNING LGT(T61)
212--0
Rarity...
There are 2 1995 CAPRICE CLASSIC STA WAG vehicles (0.037%) matching your exact options list. There are 2 (0.037%) with at least as many options.
The rarity of your vehicle is based on an exact match of your options for your year and model.
Interestingly enough it was 1 of two,.wonder where the other is,..it must have come to cananda too,.
I also played around modifying the vin and went in sequence from 185331 up to 185400 and got no returns,. tried some random numers for the last 6 and didn't get any hits either,.
Nick
Found 5,675 vehicles matching your year and model in our database.
RPODescriptionMatchesUH7CLUSTER,INSTRUMENT(COOLANT TEMPERATURE) COOLANT T/GA(UH7)
5,675UL0RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, AUTO TONE, CLOCK, ETR. STEREO,AM/FM W/AUTO REV CASSETTE,AUTO TONE(UL0)
5,527UQ1RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
5,675UQ3SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO ENHANCED SPKR SYS(UQ3)
5,564U75ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75)
ANTENNA,POWER(CHROME) PWR ANT(U75)
5,661VH9ENVELOPE,OWNER INFORMATION MANUAL OWNER INFO MAN ENV(VH9)
4,986VK3LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
5,354VM3LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
4,715V08COOLING SYSTEM,HEAVY DUTY HVY DUTY CLG(V08)
4,039V73VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
5,675V92TRAILER PROVISIONS TRLR PROVISIONS(V92)
4,039Z27MODEL CONVERSION ROADMASTER ESTATE ITT LIMITED(4BR35 & Z27 = 4BV35) ROADMASTER ITT LIMITED(Z27)
1,9791SAPACKAGE-OPTION 01 (1SA)
1,9241SZPACKAGE OPTION- (1SZ)
5,66916UEXTERIOR COLOR,PRIMARY (16U)
PRIMARY COLOR EXT,PEARL WHITE (16U)
1,9336TMCOMPONENT-COMPUTER SELECTED SUSPENSION SUSP(6TM)
5,67364IINTERIOR TRIM,LIGHT BEIGE (64I)
3,794643TRIM COMBINATION LEATHER, LT BEIGE (643)
1,2957TMCOMPONET-COMPUTER SELECTED SUSPENSION SUSP(7TM)
5,6738RNCOMPONET-COMPUTER SELECTED SUSPENSION SUSP(8RN)
5,6759RNCOMPONET-COMPUTER SELECTED SUSPENSION SUSP(9RN)
5,675AG1ADJUSTER,SEAT,6-WAY POWER,DRIVER(60-40)(VAR 2) 6-WAY PWR D/SEAT ADJR(AG1)
4,719AG2ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2)
5,304AK5RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
5,675AM5SEAT,FRONT SPLIT,3-PASSENGER,6-WAY ADJUSTER,2-WAY LUMBAR,4-WAY POWER HEADREST ADJUSTER,WITH STORAGE ARMREST FRT SPLIT ST(AM5)
1,979ARLPLANT CODE-ARLINGTON TX, CPC ARLINGTON,TX ASSEMBLY PLANT(ARL)
5,675AU0LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
5,387AU4LOCK,SIDE DOOR,ELECTRIC,AUTOMATIC AUTO ELEC S/D LK(AU4)
5,387BY1ORNAMENTATION,EXTERIOR BODY EMBLEM BODY EMB(BY1)(EXPORT)
ORNAMENTATION,EXTERIOR,BODY EMBLEM BODY EMB(BY1)
1,979B34COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
5,563B37COVERING,FLOOR MATS,FRONT AND REAR AUXILIARY FRT/RR AUX FLR MATS(B37)
5,563C68AIR CONDITIONER,FRONT,AUTOMATIC,ELECTRONIC CONTROLS A/C AUTO ELEC CONT(C68)
5,563C90LAMP,INTERIOR,FRONT AND REAR DOOR COURTESY CTSY & WARN LP(C90)
5,661DA0ARM REST,FRONT SEAT,STORAGE F/SEAT STOR A/RST(DA0)
5,563DE5MIRROR,OUTSIDE,LH & RH,REMOTE CONTROL,ELECTRIC,DEFOG,FOLDING,PAINTED O/S MIR(DE5)
5,563DF6MIRROR I/S R/V TILT, AUTO, DUAL READING LAMPS I/S REAR VIEW TILT(DF6)
5,563DL5DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
4,003D64MIRROR,INSIDE,RH VISOR VANITY,ILLUMINATED ILLUM S/S MIR(D64)
5,051D74MIRROR,INSIDE,LH VISOR VANITY,ILLUMINATED ILLUM S/S MIR(D74)
5,051FE9FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
5,163F40SUSPENSION,HEAVY DUTY,FRONT AND REAR HVY DUTY SUSP(F40)
5,675GW9AXLE,REAR,2.93 RATIO 2.93R(GW9)
4,137G67LEVEL CONTROL,AUTO AIR AUTO AIR LVL CONT(G67)
4,717G80AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
3,295ID3Unk.1,812JA2BRAKE SYSTEM,HEAVY WEIGHT,DISC,DRUM HVY WT BRK SYS(JA2)
5,675JM4BRAKE SYSTEM,POWER FRONT DISC,REAR DRUM,ANTI-LOCK(CAST IRON) ANTILOCK DISC/DRUM BRK(JM4)
5,675KC4COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
4,455KD1COOLING SYSTEM,TRANSMISSION OIL TRANS OIL CLG(KD1)
5,304KG9GENERATOR,140 AMPERE 140 AMP(KG9)
5,675K34CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
5,661LT1ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
5,675MX0TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS(MX0)
5,675M30TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
5,675NA5EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
5,169NK4STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4)
STEERING WHEEL,SPORT,LEATHER WRAPPED LEATHER WRAPPED SPORT STRG WHL(NK4)
5,075NV7STEERING,POWER,VARIABLE EFFORT P/S(VARIABLE)(NV7)
5,675N10EXHAUST SYSTEM,DUAL D/EXH(N10)
5,675N81TIRE,SPARE(FULL SIZE RADIAL) FULL SIZE RADIAL SPA(N81)
3,514PA3WHEEL,15X7(ALUMINUM) AL WHL(PA3)
5,014PA5CAP,HUB(SPORT) SPORT WHL HUBCAP(PA5)
5,017QEUTIRE ALL- P225/75R15/N WS2 R/PE ST TL ALS (9591637) TIRE(QEU)
5,675R4ZUnk.5,675T82HEADLAMPS,AUTOMATIC ON/OFF CONTROL AUTO HDLP CONT(T82)
5,061T87LAMP,CORNERING COR LP(T87)
5,402--0​
Rarity...
There are 31 1995 ROADMASTER ESTATE STA WAG vehicles (0.546%) matching your exact options list. There are 48 (0.846%) with at least as many options.
I also played around modifying the vin and went in sequence from 185331 up to 185400 and got no returns,. tried some random numbers for the last 6 and didn't get any hits either,.
Nick
Yeah you would have to change the check digit to match the number change in the serial.
Have at it, the procedure gives me a headache just reading it
http://www.dpatx.com/z28/z28-vincheck.htm
This is what it says about mine:
There are 3 1992 CAPRICE STA WAG vehicles (0.022%) matching your exact options list. There are 20 (0.149%) with at least as many options.
Very very cool.
Vehicle: CAPRICE CLASSIC STA WAG
Year: 1995
Build Date: 1995-07-31
Found 5,361 vehicles matching your year and model in our database.
RPODescriptionMatchesUL0RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, AUTO TONE, CLOCK, ETR. STEREO,AM/FM W/AUTO REV CASSETTE,AUTO TONE(UL0)
3,688UQ1RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
5,361U02CLUSTER,INSTRUMENT,KILOMETER AND MILES,DIGITAL DISPLAY DIGITAL DISPLAY CSTR(U02)
5,207U75ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75)
4,227VK3LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
4,753VM3LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
4,003V73VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
5,1481AYUnk.2,5541SPPACKAGE-OPTION #14 OPTION PACKAGE #14 OPTION PACKAGE #14 (1SP)
2,86914CTRIM COMBINATION CLOTH, GRAY (14C)
1,23414IINTERIOR TRIM LT GRAY (14I)
1,68818QMOLDING COLOR,DK GREEN GRAY METALLIC (18Q)
47918UEXTERIOR COLOR,PRIMARY (18U)
EXTERIOR COLOR,PRIMARY,DK GREEN GRAY METALLIC (18U)
4796TLCOMPONENT-COMPUTER SELECTED SUSPENSION SUSP(6TL)
4,9947TLCOMPONET-COMPUTER SELECTED SUSPENSION SUSP(7TL)
4,9948RNCOMPONET-COMPUTER SELECTED SUSPENSION SUSP(8RN)
4,9949RNCOMPONET-COMPUTER SELECTED SUSPENSION SUSP(9RN)
4,994AA7WINDOW,ELECTRIC OPERATED,QUICK OPENING QUICK OPG ELEC WDO(AA7)
4,933AG1ADJUSTER,SEAT,6-WAY POWER,DRIVER(60-40)(VAR 2) 6-WAY PWR D/SEAT ADJR(AG1)
4,755AG2ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2)
4,144AK5RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
5,361AM6SEAT,FRONT SPLIT,3 PASSENGER WITH CENTER ARMREST FRT SPLIT ST(AM6)
5,255AP9NET,CONVENIENCE CONVENIENCE NET(AP9)
5,361BC5ORNAMENTATION,INTERIOR,CARPETED LOAD COMPARTMENT PANELS CARPETED LOAD FLR PNL(BC5)
4,149B18ORNAMENTATION,INTERIOR(DELUXE) DELUXE INTR(B18)
3,963C49DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
5,361C71LAMP,INTERIOR,FRONT DOOR COURTESY FRT DR CTSY LP(C71)
3,962C96LAMP,INTERIOR,QUARTER COURTESY AND SINGLE READING QUARTER CTSY & RDG LP(C96)
4,033DD2MIRROR,INSIDE,SUNSHADE,COVERED I/S CVR S/S MIR(DD2)
3,964DE5MIRROR,OUTSIDE,LH & RH,REMOTE CONTROL,ELECTRIC,DEFOG,FOLDING,PAINTED O/S MIR(DE5)
4,678DF6MIRROR I/S R/V TILT, AUTO, DUAL READING LAMPS I/S REAR VIEW TILT(DF6)
4,015DL5DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
3,207FE9FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
4,852F40SUSPENSION,HEAVY DUTY,FRONT AND REAR HVY DUTY SUSP(F40)
4,245G67LEVEL CONTROL,AUTO AIR AUTO AIR LVL CONT(G67)
3,724IQCUnk.3,962JA2BRAKE SYSTEM,HEAVY WEIGHT,DISC,DRUM HVY WT BRK SYS(JA2)
5,361KNPCOOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
1,825K34CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
4,966K68GENERATOR,105 AMPERE 105 AMP(K68)
3,271LT1ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
5,361MX0TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS(MX0)
4,459N91COVER,SIMULATED WIRE WHEEL,INCLUDES LOCK SIMULATED WIRE WHL LKG CVR(N91)
4,028PH1WHEEL,15X7(STEEL) STEEL WHL(PH1)
5,207QEUTIRE ALL- P225/75R15/N WS2 R/PE ST TL ALS (9591637) TIRE(QEU)
4,994R4ZUnk.5,217R6AUnk.2,183R7AUnk.4,936R8TUnk.1,904--0​
Rarity...
There are 7 1995 CAPRICE CLASSIC STA WAG vehicles (0.131%) matching your exact options list. There are 9 (0.168%) with at least as many options.
Interesting, 1 of 49 single color cars, and 1 of 21 molding delete cars.
1 - 20 of 33 Posts
