As title states I Own a 1995 DCM work In progress, Going thru a whole audio overhaul. I am having some 6.5 image dynamics and want to get some either fatmat or raamat in there. I dont want to buy too much so I was hoping a forum member knew exactly how much was needed for doors.
Wow all you audio heads and have no idea of how much deadner is needed for doors?
That's because everyone is thinking the same thing as this:
Get out your friggin' tape measure and figure it out.
Plus, you don't say - 2 doors, 4 doors, front, back, buying a roll or squares, etc. OK, it's probably 2 front doors, but "a whole audio overhaul" could mean anything.
16-20 sq ft
As much as it takes!:)
According the www.sounddeadenershowdown.com could get away with as little as 25% coverage if you put the deadener in the middle of the panel and some behind the speaker, if cost is really a consideration. Personally I plan on doing about 75% with deadener in the doors because they are a major noise source, I also plan on 99.9% coverage with a sound barrier for sound isolation which makes my music sound better.
