...Any tips on best and easiest way to bleed my brakes after installing the bolts
Several ways of doing it really.
1)
One man operation:
A)
Gravity bleed. Do a search for more comprehensive procedure. Get 4 pieces about 1 1/2 feet long of clear 3/8" vinyl tube. Attach one end over bleeder nipple, the other in a disposable bottle. Open all bleeders and as the name suggests, let gravity do its thing. Check periodically to assure master cylinder doesn't run dry and top off w/ new fluid. When new fluid comes out on all 4 corners, tighten screws and test brake pedal feel. Should brakes still feel loose, move on to one of the following operations. Remove hoses, discard old fluid/bottles and done.
B)
Speedbleeders. Do a search for more comprehensive procedure. Get speedbleeders for all 4 corners (front and rear are different sizes) and replace the OEM's w/ these. Get 1 piece about 1 1/2 feet long of clear 3/8" vinyl tube. Attach one end of hose over bleeder nipple and the other in a disposable bottle. Assure all bleeders are tight and that hose is tight on bleeder nipple. Open the RR bleeder and depress brake pedal completely to the floor and release repeatedly. Check periodically to assure master cylinder doesn't run dry and top off w/ new fluid. When new fluid comes out, tighten screw. Repeat procedure sequentially at all 4 corners moving from RR to LR to RF to LF. Upon completion, should brakes still feel loose, repeat entire sequence again. Remove hose, discard old fluid/bottle and done. Some who bleed this way remove the speedbleeders afterwards and replace w/ the OEM's because they're leery of the speedbleeders failing.
C)
Submersion. Do a search for more comprehensive procedure. Get 1 piece about 1 1/2 feet long of clear 3/8" vinyl tube. Attach one end of hose over RR bleeder nipple and assure it's tight and the other end in a disposable bottle. Fill the bottle w/ new brake fluid until the level is above the bottom of the hose. Use a wire tie to make sure the hose doesn't work it's way out of the bottle/get above the fluid level. Open the bleeder and depress brake pedal completely to the floor and release repeatedly. Check periodically to assure master cylinder doesn't run dry and top off w/ new fluid. When new fluid comes out, tighten screw. Repeat procedure sequentially at all 4 corners moving from RR to LR to RF to LF. Upon completion, should brakes still feel loose, repeat entire sequence again. Remove hose, discard old fluid/bottle and done.
2)
Two man operation:
A)
Communication is the key. Do a search for more comprehensive procedure. One person in the cockpit, herein called "Jack". One on the wrench, herein called "Fred". Get 1 piece about 1 1/2 feet long of clear 3/8" vinyl tube. Starting at RR, attach one end of hose over bleeder nipple and the other in a disposable bottle. Fred makes sure Jack's foot is off the pedal. Once assured, Fred loosens bleeder screw and retightens but only "just snug" and NOT "cranked down" . Fred then signals Jack to "pump" the brake 3-4 times and to "hold" the pedal down after the last depression. Jack pumps the brake pedal and then signals to Fred he is holding the pedal down. Fred loosens the bleeder 1/4 to 1/2 turn and fluid shoots out of the bleeder. When done properly, Fred will see no more fluid coming out of the bleeder at the same time Jacks foot depresses the pedal completely to the floor. Fred then tightens the bleeder screw just snug. Once tight, Fred then signals Jack to "pump" the brake 3-4 times and to "hold" the pedal down after the last depression. Jack pumps the brake pedal and then signals to Fred he is holding the pedal down, etc... This process is repeated about 3-4 times after which time Jack takes his foot of the pedal and Fred checks to assure master cylinder doesn't run dry and tops off w/ new fluid. Once new fluid comes out of the bleeder, tighten screw completely. Repeat procedure sequentially at all 4 corners moving from RR to LR to RF to LF. Upon completion, should brakes still feel loose, repeat entire sequence again. Remove hose, discard old fluid/bottle and done.
There are even a couple of other more creative ways involving power seats, 2x4's, etc..., but this should point you in the right direction.
