Since that stick was created, its been discivered that our cars have quite a bit more tolerance for backspacing and offset. The 20x10 Eagle 225's used by several members with lowered cars, have an offset of +2. Which is about 5.57 inches of backspacing. So there is some room for error in the recommended specs at the top of the page.
If your wheel has 6.8 inche BS, and the recommended is 6.5 inches (see chart at top of section) You may not need a spacer at all. a 1/4 inch spacer should give you a good fit, if you need it at all. Have the wheels redrilled and have the center bore opened to 78.1 and you should rock.
That's the great thing about BMW wheels, they usually dont need adapters.
