You will need a Terminal tool! Needles, nails, and push-pins will not work.
LISLE Part # 14900 is what is pictured
(The green Lisle tool will work also, but it is not spring loaded like the 14900 is)
And of course, the Connector itself.
A black, red, blue, or orange 3 pin Weather-Pack WILL NOT WORK!
The 'Green' Connector is indexed to fit the MAP Sensor.
You can buy a pigtail to rob the end from the following:
DORMAN Part # 85115
GM Part # 12085502
AC-Delco Part # PT123
These get expensive. If you want a connector for a lot less- email or PM me.
Here are my instructions on how to fix the green plug.
(skipping the open hood, remove home-base, etc)
Required parts and tool:
Step 1 - Locate green plug
Step 2 - Unplug from sensor, and remove (probably broken) Secondary Lock.
Step 3 - Insert Lisle spring loaded terminal remover, and PUSH until it pops out.
Step 4 - Insert removed terminal into new plug. (ONE AT A TIME!)
DORMAN Part # 85115
GM Part # 12085502
