Im getting hardly any airflow coming out of my a/c vents. The a/c fan motor is spinning hard but no air coming out the vents....
I have air flow from floor and defrost vent. Is the control door on the passenger side ? If so it's also closed.Check the floor vent, and defrost vent for airflow. If they have flow, you may have an issue with the control door linkage.
Fan works on all 4 speedsIf it works on all four speeds... Probably a failing blower motor. Very very common. Easy to get to and to swap out.
Blower motor works on all 4 speeds.If it works on all four speeds... Probably a failing blower motor. Very very common. Easy to get to and to swap out.
Control door is closedCheck the floor vent, and defrost vent for airflow. If they have flow, you may have an issue with the control door linkage.
Thanks for the comment. I looked at the blower .motor and it doesn't look like its OEM. I do not have any vacume leaks . I wish I could feel what it felt like when the car was new and compare to now. Maybe that's as good as it gets.Does it have the weak aftermarket Blower motor that is 1/2 the size of the oem? Do you hear any hissing under the dash? I had a stuck blend door the other day major vacuum hiss under the dash and rough engine from the vacuum leak
To get the original feel, you need to recharge the system with R12 replacement, and put an OEM blower in place of the aftermarket one. The replacement R12 is about $44/lb. The fans can still be found in junkyards. An option to changing the fan is to put a foam gasket on the bottom of the inlet so that it is close to the top of the fan squirrel cage. 1/4" would help a lot, because the distance is almost 3/8". Just be sure it does not hit the top of the fan.Thanks for the comment. I looked at the blower .motor and it doesn't look like its OEM. I do not have any vacume leaks . I wish I could feel what it felt like when the car was new and compare to now. Maybe that's as good as it gets.
