I have a water pump question
569 Views 18 Replies 9 Participants Last post by  storm9c1
When a water pump on our engines go bad, can someone tell me what happens internally in a detailed fashion? I'm trying to understand what goes wrong internally. Thanks.
1 - 19 of 19 Posts
Typically the bearing seal starts to leak which is why the WP has a weep hole so when you start to see it dripping from that hole you replace it. Beyond that the bearing can actually freeze up which will stop the WP from functioning and overheat will happen quick. Rarely the impeller breaks which will also cause very quick overheat.
The problem with the LT1 WP is the weep hole being behind the pump pisses on Opti, which kills it. Even when you just catch the WP "weeping" (read you won't yet even see coolant on ground) the Opti has been exposed so on WP swap pull Opti and remove cap & rotor and optical wheel and carefully clean it out with Q tip. Reassemble using loc tite on rotor screws. The Opti will be fine.
  • Like
Reactions: 3
Pretty much what BALLSS said.
With uncontaminated clean coolant, the H2Opump tends to wear out gradually, rather than fail suddenly.
If you change your coolant every 2 years, pop off the inspection cover after draining to check inside it.
It was once popular to add a zerk fitting and a clear hose to the weep hole so Opti would not get pee'd on.
This would also keep the belt dry.
If you ever notice power steering misbehavior, the belt might be getting pee'd on; check that weep hole.
I used to just put tape on the top of the Opti-Spark (where the Opti- & the -Spark meet).
  • Like
Reactions: 1
I have always used a skim coat of dialectic grease on opti cap O ring to case mating and around rubber gromet on the Opti harness 4 pin connector to prevent coolant from entering the Opti. Unfortunately for Opti, oil can enter through worn shaft bearing. It can be cleaned out but will continue to enter through bearing so repeat cleaning will be necessary on an otherwise working Opti
The "gutted" 90 degree zerk fitting with vacuum hose extending down is a good mod to direct weeping wp coolant away from Opti and belt.
  • Like
Reactions: 3
I wanna thank each of you for your input and sound advice. You all definitely answered my question and then some. I couldn't ask to be amongst a better community of friends. 😎
Let me add a few details as well.
The LT1/L99 water pump is shaft driven from a cam gear. While this was an innovative idea from GM engineers to eliminate a belt, the coupler design became a weak link instead.
Many failures I've seen involved the outer bearings being completely destroyed. The symptom is seen after removal the WP and the bearing housing is blown apart, or the balls fall out or are visibly ready to fall out. Usually leaking is a side effect of the destroyed bearings.
The root cause is a seized WP drive coupler. The coupler seizes onto one end (or both ends) of the shaft. Any amount of wobble, even a tiny amount, at that point will tear up the WP bearings.
The the solution is to reinstall the WP properly. Meaning replace the o-rings on the both sides (WP and engine side) and repack the coupler with a tacky grease that won't harden. The o-rings are critical to prevent dirt, grime, moisture from entering the coupler. And also to prevent grease from spinning/flinging out. Remember this coupler spins at high speed. As soon as grease flings out, it's not long before it seizes and eats bearings.
They really should have designed a more flexible fitting. Perhaps a small yet more robust CV joint of some sort. Even a tapered coupler to allow for some wobble? I dunno. But that would solve the problem 100%. And likely increase production cost. So there you go. They knew the existing coupler design made it to 36K miles (enough to pass warranty) and called it a day.
Hope this helps.
  • Like
Reactions: 2
My bearing went bad. Pretty sure that's most cases.
if you ever convert to EWP you will see what a cheap POS the mechanical pump bearing is. If AC Delco would have spent at least $.10 more for a better one the pumps would likely last like any other mechanical pump. I suspect offshore replacements are even worse.
I still have a NIB 20 year old AC Delco WP the dealership gave to me when the 7th OEM one failed after 500 mi. Car was 3 years old and then out of warranty. My Meziere has been on since and has over 90k mi on it. YMMV. The mechanical makes a great door stop though
  • Like
Reactions: 1
If you were getting only 500 miles per pump, then your engine has a machining tolerance issue. The pump is not registering correctly in relationship to the block. Common? Maybe. Prevalent? not likely.
  • Like
Reactions: 1
Agreed. This was my primary point -- the straight coupler is too rigid and does not allow for much tolerance drift. Doesn't matter how good the bearings are, if you put improper loads on them, they will fail. I speculate that a better coupler design that accommodates misalignment, tolerance drift, and slight imbalance would reduce failure rates by 90%. Basically everything a belt drive does inherently. LOL.
An electric water pump is fine too. But they do come with pros and cons that have been debated to death in other threads.
  • Helpful
Reactions: 2
the WP's were all leaking from weep hole and killing Optis according to dealer as the car was under warranty
What I discovered though is that Mr Goodwrench during one of those swaps, likely the 1st or 2nd one, was the check valve on the vent harness was reversed (assume Gomer pulled vent harness off and FU putting it back on) eliminating any vacuum to purge opti. Crud quickly built up in them thus killing the Opti. Dealer just kept replacing WP & Opti as a pair under warranty. Service Mgr showed mw the crud in opti. Dealership was cool and even sponsored SoCal SS club back then. They would install H/C if you wanted. It was after 500 mi on the last one I discovered the reversed check valve and since the car was out of warranty, I just went EWP and to this day that EWP has been on 2 motors without issue.
There was never a coupler alignment issue. If you ever gut a mechanical pump you will see what a cheap bearing/seal that is in it. Unfortunately, the weep hole position coolant is then pissed on Opti.
And this was determined how?
I agree. I have taken apart WPs, both early GM ones that failed and later remans. Yes they aren't made great. But no cheaper than any other belt driven 350 SBC pump I've ever taken apart. My point being is that some of us, with proper installation techniques, get reasonable life out of the water pump.
In the early days, I didn't know better to do these steps (and of course WPs failed or leaked every 30K or less):
  • Replace the shaft O-rings.
  • Properly clean and grease the coupler and shafts.
  • Check position on the alignment pins during reinstall (sometimes remans didn't fit properly).
  • Clean the threads, apply thread sealant, and properly torque the bolts to FSM specs (over tightening bolts and over crushing the gasket will also ruin the bearings).
  • Add 1-2 tablets to the cooling system (especially if doing a drain and flush).
Once I got better at doing the job correctly to include every step above, the problems decreased significantly. My daily drivers are B-Bodies.
Sorry, I didn't jump on the electric WP bandwagon. On the contrary, I worked with guys at the track back in the day who had overheating problems with electric WPs -- and it left a bad taste in my mouth. Granted that was decades ago, like I said, pros and cons. Don't need to turn this into a "which is better" argument. Just saying it's not all doom and gloom just because someone runs a mechanical WP.
Best thing I have done to my wagon in the 6+ years I have owned it was putting an EWP on it two summers ago. Stripped water pump drive left me with two choices, rip front of engine apart (at the rate I do things to my own junk it probably still wouldn't be finished) or go electric. Car runs cooler in the Florida heat and a failed bearing letting coolant piss all over my still going 234K Opti is not a concern.
Interesting note , I have seen two types of bearings in OE LT1 pumps.
One had an inner race like a typical ball bearing set up and a straight shaft.
The other, the shaft WAS the inner race.
Anyone know which was first , which was second type ?
I don't know off the top of my head. I haven't taken them all apart. They usually just get thrown back in the box for core return.
But what I do know is that my Impala SS has ~20K miles on it and still has the original WP from the factory. So when it does go (if it goes in my lifetime before I ever sell it), I'll let you know what design it uses. ;)
I'm think one design is chosen over the other for reman reasons. Common sense tells me that the remans may have the version with discrete off-the-shelf bearings. The remans also got polished steel heater hose tubes versus stainless steel of the originals. You can tell by which ones rust in the rust-belt areas. There are other differences, but those are the two main ones. I wonder if the so-called "new" ones (non-GM, non-Gates) use stainless tubes? Or is everyone cheaping out now. Curious to know what bearings those use. Last one I did was a Gates and I didn't pay attention. Car got totaled a few months later and the engine is sitting in my garage. I'll give the tubes a magnet test (albeit not a guarantee that's stainless or not).
The one pump I rebuilt ( long time ago a guy wanted a ceramic coated pump ) the jobber kit I got, the bearing and shaft were integral to each other.
The
only time I ever did have anyone work on my Impala was when it was under new car warranty (other than alignments and rear gears after it was out of warranty). Unfortunately, as a result Mr Goodwrench caused the problem of failing Opti's until I discovered the blue/white check valve was reversed (they are one-way valves). All WP's there were replaced, along with Opti and vent harness, were factory or AC Delco parts installed by dealer. The 6th WP was the one I gutted, dealer installed, and that bearing had no ball bearings.
Agree on points made about a clean and greased spline coupler and new O rings on respective Opti & WP drive splines. I keep both those in my parts stash.
Every other car I have ever had uses a mechanical and I have swapped several of those over the years bt consider their life spans normal.
I also was "skeptical" of using an EWP on a street car in terms of longevity so I have the coupler in console if it ever crapped on long drive as I could just put a mechanical back on. 15+ years ago I chose to buy a 2nd EWP as spare to keep in trunk as I could just replace it on the side of the road in 10 min wearing a Tux. That spare has never left the trunk in over 15 years but with over 90k mi on current one, I assume at some point it will fail. No idiot light or buzzer needed. I have a temp gauge, among others, I monitor just like my other cars.
I will note I regularly drag raced the car and spun motor to 6k rpm back when the SoCalSS club would go to Pomona when the car still had mechanical WP. IDK if those higher than normal RPM's "contributed" to any premature failure which was leaking from weep hole. For me, the EWP has proved to be considerably more reliable. YMMV
  • Like
Reactions: 5
My rebuilt pump seal and bearing failed, exposing ball bearings. I got a brand new ACDELCO pump made in China which had splines that did not fit my original coupler or the new coupler that I had ordered. Rockauto refunded my purchase, and the rebuilt Gates pump has been working for a while.
That's sad, funny and disappointing all at the same time. My luck with online AC Delco parts (at least for these cars) has been bad lately as well. All offshore... cheap low end parts. If you want new (or refurb), Gates is probably the defacto pump to go to now. They were the GM OEM anyways if I recall.
1 - 19 of 19 Posts
