1 - 14 of 14 Posts
Springs.
I want to lower my 96 Caprice. I had Eibachs on my 93 and liked the amount of lowering but they were a little too soft for my liking. I would not mind going lower and am even considering the early bilsteins (can't remember the #'s) from the boxy's cuz they're supposed to be stiffer. I would like to toss the car around through exit ramps, etc. but do not need a full autoX setup. A little firmer is better. I just checked using the search but was unconvinced on any particular set up. Are the SST's still around? The H&R's seem interesting, and you can't beat the price on the Intrax'. Like I said, I know it's been done to death, but please...one mo' time. TIA for any help.
Sean
Hey Sean.
If you want to go a little lower than Eibachs, you may want to look into Hotchkis lowering springs.
http://www.hotchkisperformance.com
Check some of my threads from the past months or so. I had decided on the stiff Bilsteins as well, and I purchased them from http://www.shox.com
My shocks should be here tomorrow
As for springs, I personally wanted something jst a tad bit lower than stock SS, but I have no problem with SS springs. So a friend's uncle (mechanic at Chevy dealer) is going to give me his price on SS springs, but if I do not go with SS springs I am planning on buying Eibach.
Some websites of interest:
http://www.hotchkisperformance.com http://www.shox.com http://www.thunderracing.com
If anyone else can think of any helpful websites, please post them! ;)
Hope this helps, Sean :cool:
Scott;
Thanx for the consistent help in this and other posts. That thunderracing link looks like a good one, i'll definitely be bookmarking that one. How much were your shox total incl. shipping? Thanx again.
Sean
Always glad to help out, Sean ;)
I ordered the stiff Bilsteins from shox.com (they have a phone # if you want to call instead of giving your credit card # out over the internet):
Front: Part # B46-1104, $62.45 each.
Rear: Part # B46-0929, $62.45 each.
$62.45 * 4 = $249.80, and $20 for shipping brings the grand total to $269.80.
They were shipped on Monday and I just recieved them on Friday via UPS Ground. I am still waiting for my friend's uncle to give me a good time to install them, as well as settle between Impala SS springs and Eibachs.
Good luck in your search, and let us know if you need any other advice :cool:
Intrax here MightyCaprice with the linear rate Bilsteins. I like them pretty good and your right once agin, they are cheap. From what I have drove my car I would recogmend them to any one. Ride is good and shocks make a big difference. Just my $.02, hope this helps.
Kevin
Hey Kevin, do you know off hand if the linear rate ones are the early shocks or the later ones. That's probably the route i'll be going with the intrax and bilsteins. I'm switching over the front bar to the F-bar next weekend. I'm holding off on the rear til I can upgrade the ctrl arms. Probably BMR's , that'll have to wait though til I can convince my wife on the price of the bilsteins.
Thanx for the price Kevin, that's just what i'm looking for.
Sean
Whoops, I mean thanx for the price Scott. Sorry.
Sean
T
Linear shocks are the early ones - same ones 9C1scott got. # 1104 and 0929
Terry
Yes they are the early ones. Here goes the year models...
Full Size: Caprice Classic, Caprice, Impala 77-90 RWD; Except Wagon HD (front)B46-1104 (rear)B46-0929
Full Size: Caprice Classic, Caprice, Impala 77-90 RWD; Wagon HD (front)B46-1104 (rear)B46-0929
Full Size: Caprice Classic, Caprice, Impala 91-96 RWD; Except Wagon HD (front)B46-1516 (rear)B46-1517
Full Size: Caprice Classic, Caprice, Impala 91-96 RWD; Wagon HD (front)B46-1516
Here goes you a link to the best price on the net...
HERE!
Hope this helps.
Oh yea I got my springs from summit, I did this for the simple fact that they have them in stock and ship fast. I think I could have saved like $10 getting them some where else but I didn't want to have to ask my self if the company was really reliable.
Kevin
Hey Kevin; do you know if your alignment will stay within specs with the intrax or is it going to be slightly out...way out, or what. Also, I can get the rear Bilsteins from Autozone for $54.95
but fronts are $89.99
So i'll order rears from there and fronts from shox.com. Thanx again.
Sean
I couldn't get mine to stay aligned with Intrax so I went back to the 9C1's.
This was a local "basic" shop and 285-40-17 520's. Now with 225-70-15 RS'A (winter here) it only pulls to the right.
117k and no front end work done that I know of.
Not much help....just what has happened to me.
So it wasn't a prob. getting it aligned, just for whatever reason it wouldn't stay aligned? I guess, the question is can you get the alignment to factory specs or anything close?
Sean
Discussion Starter #13
I guess by local basic shop I should have said...not a clue shop. I had to tell them the second time that it should be aligned to Impala SS specs not Caprice. I think the Caprice SS script on the rear quarters confused them.
Anyway they told me over and over that it was in "factory specs" whatever that meant so I guess the answer was yes it could go to specs.
BTW it's going to a quality shop in a month for a complete front end going through but first I have to try and decide which springs.
Good luck.
1 - 14 of 14 Posts
