Was testing IAC while off throttle body to see if it was working. The pintle came all the way out of the IAC stepper motor. Is there a way to get it back in where it needs to go? I gently threaded it back in,but it's still way too far extended. Any ideas?
Purely from your description sounds like running out of threads (or stepper) before otherwise bottoming out. Any way to 'pre-thread' deeper first before running it home? I had to do a similar thing to re-assemble a rotating e-brake assy back together on an old Riviera.
Those things USED to be a maint. item when they were $30. Geez $80 now?
I can not find it in the manual right now, but if you search IAC cleaning you will find many references to not touching a used IAC pintle's position. I have a bad feeling that if manually moving the pintle causes damage you have damaged it.
It is not a DC motor it is a stepper motor like in a hard drive. It has two coils that are pulsed in sequence to move it back and forth. The dealer was forced to buy a special tool to check the IAC.
Bottom line the IAC parts are supposed to be too weak to survive manual pintle movement.
Bummed out because IAC turned out to be good (before pintle shot across driveway) ,and seems like pintle could be retracted if I could think of,or discover a way...
Update: Only way to retreat pintle is with the Kent-Moore tool. Saw a couple on ebay for around $100,but decided to take a chance at my local Chevy dealer. After some rummaging around,they found theirs. They let me use it,and tool worked like a charm. Happy,happy,happy... Thank you, Chevrolet....
Just curious but what is the Kent Moore part # for this tool. That was nice of the dealer/Service dept to let you use that specialized tool. I had similar situation with an old Buick Regal which had a Transverse Leaf Spring on the rear and required a special tool to replace the Struts. Of course none of the Loan-a-tool places would have a tool like this. Contacted a local Dealer Service dept and told the shop guy what I was doing and was "curious" if they had this tool and would rent it to me. I could not do this job at their shop and needed to take the tool with me.
After he jokingly said, "I found it and brushed the Dust off for you", they were extremely nice and let me borrow the tool. I offered to leave a copy of my license or even a credit Card for a deposit but guess I have a trusting face and they told me to just bring it back when done. Of course I did (good Karma) return the tool and took them a box of Donuts as a TY. Most may never think to check with the dealer for special tool like this but a lot of these tools aren't used by them anymore and they may not mind. What's the worst they can say? ...."No"
On your IAC repair - I suspect I have a IAC valve that is also having issues. Has to have at least 150K on it now and I've noticed some random Idle issues and even a hesitation once in a while after the car is warmed up. A lot of the symptoms Ive read about seem to indicate a bad IAC. But dang this thing is a pricey little part but if I'm going to swap it out, it will either be a Delphi or AC part.
The IAC passages in the throttle body can,and do accumulate a lot of oil,carbon,gunk that is easier to remove by separating the castings with throttle body off the car...
Hello, So I have a small fuel leak at what appears to be at the top of the tank. I dropped the tank and pulled the sender unit. Looked for cracks at the sender unit pipes. Looked good. No rust. Pulled the sender unit out. Replaced the strainer and sender O ring since I was in there. Replaced...
Wondering what parts we might need to consider throwing at it, if any... When it was stored, it was working perfectly, and fuel was siphoned out. We had forgotten that when it was attempted to fire it up again, and so got much cranking but no catch/turnover once we replaced the battery...
I have a 96 impala SS and I have to direct wire the fuel pump to work under the hood To make the fuel pump work I am love on that can someone tell me what to do to make the fuel pump come on when I turn on the ignition well it does prime when I turn on the Key and start it it try’s to run but...
If im driving and it feel like my engine aint pushing how it supposed to run,feel like its not geting some kind of power. I think its called stalling when pushing the gas pedal n its not accelerating how it should. What would the problem be?
