if the ignition coil isnt working....the car wont start correct????? i tested the fuel pump and it works when i took it out.......but when i turn the key and put the fuel pump in.....and i turn the ignition...it doesnt make one noise.....the fuse and relay are both good and work fine. i recently replaced the ICM. wont the car wont start....Do you think the ignition coil could have shorted out? thanks
