I've heard people talk about and I have seen thses on websites but I'm not sure what they do or where they are located on the engine.
94-96 B-body vehicles the ignition coil is mounted on the ignition module bracket on the driver side cylinder head and has a wire going from the coil to the optispark. On 93 and Older B-bodies I would assume its near the distributor so trace the coil to distributor wire from the center terminal of the distributor cap to the coil(have only owned 95's so never took a good look at 93 and older engines). - Peter
