Another side note regarding SEO cars... even though SEO do not have a "theft deterrent relay" in the starter circuit as shown in the schematic above, the VATS module is still installed and connected to the PCM. But on the SEO cars, it's left in open (unprogrammed) mode. Meaning it never learns a key. And thus always blindly provides the correct fuel enable signal to the PCM. If you pull the PassKey fuse on a SEO car (#14 on a '94 Caprice for example), and start the car, it will run for a moment and then die as the PCM shuts down the injectors due to lack of VATS signal.
