2000 Impala 3.8 L
I replace the harness and my dash I don't know what wires go where on the ignition switch the mounts on the steering column and I don't know what wires go where help please
2000 Impala 3.8 L
The pieces were cut off the end of it there was no connectors so I'm trying to wire switch to it here's a picture of a switch and I'm trying to put in it I need to know just what it does which ones I should put where the ignition is out of a 96 Impala I'd like to know where to hook the wires on what page on this ignition switch if possible thanks for all helping opinions
Try getting a used harness, clip the pigtail off, and match the wire colors. You may be able to get a pigtail in the aftermarket. The 91-96 B body harness connectors should all be the same for the ignition connector. I believe the VATS is a separate connector.
  • Like
Reactions: Jimpala95
