OK, Just a little info for your inspection...
On the SPID label for the Fleetwood:
GM8 = 2.56 axle (standard on Fleetwood)
GU6 = 3.42 axle (trailer package)
GW9 = 2.93 axle (standard on Fleetwood Brougham)
G80 = Limited Slip
U89 = trailer wiring harness
V4P = 7000lb towing provisions
Don't get upset if the V4P isn't there. As long as it is the Brougham package, all of the heavy duty stuff is already in place... you will just need to bump up the axle and maybe add the limited slip.
My number is in your P.M. in case you have other questions at time of inspection.
Good Luck!
G80 = Limited Slip
Good Luck!
