A
Does anyone know if the Impala and the RM's share the same LCA's? I have a '92 RM sedan that I just put Belltech springs into, and now the rear of the lca is about an inch from the bottom of the frame. Were the impala lca's designed with more clearance from the factory? I was thinking that i'm either going to notch the frame or use different LCA'a (if different).
A
The factory LCAs are the same dimensions for all 91-96 B-bodies. Not all included swaybar install provisions (i.e. brackets inside the control arm), but it is the same dimensional stamping.
Aftermarket LCAs might get you a little more clearance here, but that close on things is telling me the springs are too low.
