I've swapped the brake system (FR/RR calipers, disks, etc) from an Impala SS into my Olds Delta 88, and it seems I'm having some front/rear bias issues causing the rear to lock up. I have the master cylinder from the SS and the attached proportioning valve plumbed to the frame mounted proportioning valve that came on the 88. The rear port from the SS valve is plumbed to the front brakes on the 88 valve, and the front port on the 88 valve is plumbed to the rear brakes.
Is this the correct setup? This appears to be the way that ABS delete Impalas are plumbed. Do I have this correct? Could this be a stuck deferential valve in the Impala proportioning valve? Would it be better to ditch the dual setup, and just install one disk/disk valve?
Thanks!
Thanks!
