Do I believe my speedo or do I believe my tach? If you work the numbers for a stock configuration then what you will see is:
@5,600rpm
1st....47.7mph
2nd....89.9mph
3rd...146.0mph
4th...209.8mph
My Black Car shifted out @5,600rpm W.O.T. thru 3rd & into 4th but the speedo only showed about 137mph ... now according to the tach it did 146mph in 3rd & beat 150mph before I backed-out but the speedo never showed it ... that was brand-new w/ just over 1,500 miles on it & bone stock ... let me say that it was not going to "pull-out" high gear ... the doors were about to blow out ... damn near took it back to the dealership ... felt like it should have done better...but it didn't! That's not really why I bought it anyway...right? It did O.K. for a Stock Four-door Chevy! The real deal is @ 70mph it is turning 1,868rpm ... now that's crusing!
I have the six speed in now & now it won't "pull-out" 5th gear ... here are the numbers w/ stock 3.08's @ 5,600rpm:
1st....54.9mph
2nd....82.1mph
3rd...112.3mph
4th...146.1mph
5th...197.4mph
6th...292.1mph (1,342rpm @ 70mph)
It takes a 4.31 but 4.33's is a close match @ 5,600rpm...here's the numbers:
1st....39.1mph
2nd....58.4mph
3rd....79.1mph
4th...103.9mph
5th...140.4mph
6th...207.8mph (1,887rpm @ 70mph)
O.K.-
Here is where I've been going...
This works with-out changing your carrier 4.88's @ 5,600rpm:
1st....34.7mph
2nd....51.8mph
3rd....70.9mph
4th....92.2mph
5th...124.6mph
6th...184.4mph (2,126rpm @ 70mph)
This should be the starting place for top-end efforts ... 5.38 @ 5,600rpm:
1st....31.4mph
2nd....47.0mph
3rd....64.3mph
4th....83.6mph
5th...113.0mph
6th...167.2mph (2,344rpm @ 70mph)
(This looks like a nice gear if you don't do alot of long distance driving & even if you do ... final drive is 2.69:1 that is real long leggs for a direct drive final tranny like the 400-Turbo!...If you could pull-out high gear then @ 7,000rpm you would be doing 209mph)
Now...Let's get serious...6.14's @ 7,000rpm:
1st....34.4mph
2nd....51.5mph
3rd....70.4mph
4th....91.6mph
5th...123.8mph
6th...183.2mph (2,675rpm @ 70mph)
In conclusion:
I don't see any 1/4mi gears in the Summit Book for six speed Impalas...unless you think that 3.07:1 is a 1/4mi gear...that's what the 6.14's are like in final drive ratios...take a lot of "stroking that stick" to get all those gears done...you couldn't do it! ... You might see the start of 5th!
Are you freaking yet? ... Check the final ratios in all the gears:
1st...16.33:1
2nd...10.93:1
3rd....7.98:1
4th....6.14:1
5th....4.54:1
6th....3.07:1 (about the same as stock w/400)
The stock 3.08:1 / 4L60-E final ratios are:
1st....9.42:1
2nd....5.00:1
3rd....3.08:1
4th....2.14:1
If you followed all that then you must be a nut too! ... If you didn't ... who cares!
Later!
Wild Bill
