I found this rear. It’s only $200. Do y’all think it’s worth it or is it too far gone?
Thanks in advance.
Thanks in advance.
Thanks for the advice. Never built a rear, have the service manuals and a friend who’s built a bunch if I get into trouble. But I already have most of the tools needed. Only need a yoke holder. Been collecting tools for the last 30 years 😁Have you ever rebuilt a rear? You need some specialty tools: Yoke holder, dial gauge, inch lb torque wrench, and the usual compliment of bearing and seal removers/installers. You can use a 0.038-0.042 inch pinion shim, and it will be right the first time. Follow the instructions in the FSM, and you will get a good quiet rear.
Someone with better eyes might be able to tell if that is an Impala diff or a 9C1, I can't.
Impala 1598mm - wide
Buick sedan 1566mm - narrow
I do not first hand know how much room the stock Buick has, but this could affect wheel tire choices if you are doing anything other than skinny factory.
Shims , ,, no comment
Good catch! Thank you. After talking to the seller. It is in fact a 96 police rear. Hopefully it works.He had it listed as a 96 impala ss rear.Someone with better eyes might be able to tell if that is an Impala diff or a 9C1, I can't.
Thank you for the tips👍 Plan is to totally rebuild it while I’m still using the car to commute. So if it doesn’t have a posi, it’ll give me an excuse to get a Truetrac. Mainly want it for the brakes.Note that G80 limited slip was an option on 9C1, many people think they came standard with posi. Gears were also different depending on L99 or LT1 (LT1s got 3.08s).
If I were buying, I would take the diff cover off for a few reasons:
- confirm condition of gears (no rust/chips/broken parts)
- gear ratio (count teeth, but numbers stamped on edge of ring)
- you'll see if there is posi (if the tag is gone from the cover)
Why it has leaf spring?!,is it out of the truck?I found this rear. It’s only $200. Do y’all think it’s worth it or is it too far gone?
Thanks in advance.
Coil spring mounts on the top.Why it has leaf spring?!,is it out of the truck?
Would you happen to know what exactly is listed under hens teeth and Unicorns?Does it have functional emergency brakes? If not, some of those replacement parts can be found in the catalog under "Hen's Teeth" and "Unicorns". IMO the original design is marginal and an afterthought, but it's still better than nothing. Getting them to work properly in the rear end you bought could be a challenge. Good luck!
