SALE PENDING ON ALL OF THE PARTS.
THANK YOU FOR YOUR INTEREST.
I am in the process of cleaning out my garage and have the following Impala parts, almost all of which is new GM in original boxes / packaging. If you were to price these parts from the usual sources I would estimate +/- $10,000, however a lot of it is obsolete so it is hard to put a price on individual items.
I’ve done my best to describe the items and added part #’s, but I apologize if there are any inaccuracies with the part #’s.
I really don’t have the time to sell piece by piece at the moment and was wondering if any of you would be interested in all of it at, say, $5,000?
It would have to be picked-up, as shipping would be difficult. I’m in the Clearwater / St. Petersburg area of Florida.
You are welcome to PM me your best offer if you are interested. Business and family commitments keep me busy, as ever, but I will respond as soon as I can.
Please don’t ask for dibs on individual items at this time, as I don’t want to be overwhelmed by inquiries and not be able to respond quickly to you.
Thanks.
Roger.
1 A/C Compressor Relay - #12077866
1 Accessory Bracket - Chrome plated
1 Air Dam - center only
2 Air Dam (3 piece sets)
1 Alternator - Reconditioned - AZ Duralast DL-1400-6-4 140amp
3 Alternator Bolts - Long - #11509202
6 Alternator Bolts - Short - #11516109
1 Arm Rest Padded Gray L/F - #16669943
1 Arm Rest Padded Gray R/F - #16669942
1 Arm Rest Padded Gray Rear - #16669955
1 Arm Rest Padded Gray Rear - #16669954
1 Ash Tray / assembly - #10197140
1 Car Bra
1 Carpet Retainer - Gray plastic Front D/S - #10253509
1 Carpet Retainer - Gray plastic Front P/S
1 Carpet Retainer - Gray plastic Rear - Left
1 Carpet Retainer - Gray plastic Rear - Right - #10222524
1 Center console lid - #12531192
1 Center Shifter Console (PRND etc.)
2 Child Security Lock stickers
1 Cigarette Lighter - #11516141
1 Coolant Recovery Reservoir Hose - #10219445
1 Cross Drilled & Slotted Rotors (2 front / 2 rear) - new set
1 Dome Light Assembly (GM) - #22637725
6 Door Bezels with pull handles - #16671421
1 Door Handle Bezel Assembly - #10250961
1 Door Handle Bezel Assembly - #10250960
1 Door Handle Bezel Assembly L/H - #10250958
1 Door Handle Bezel Assembly R/H - #10250959
1 Door Mirror w/pigtail - P/S - Primed
1 Door Panel Lamp (Red/White) D/S - #16671511
1 Door Panel Lamp (Red/White) P/S - #16671510
1 Door Switch Panel Assembly (Window / Seat) D/S - #10188965
1 Door Switch Panel Assembly (Window / Seat) P/S - #10188944
2 Emblems - Impala (Short legs) Left - #10424491
2 Emblems - Impala (Short legs) Right - #10424491
1 Fan Shroud Panel Assmbly w/ factory stickers - #10281082
4 Fan Shroud Screws
1 Fender Cover "Impala SS" (New - but foam back peeling)
1 Filler Cap - Locking w/ 2 keys
2 Floor Mats Front - OEM Gray (new - but foam backing is peeling)
2 Floor Mats Rear - OEM Gray (new - but foam backing is peeling)
1 Glass Window D/S front door
1 Headlight bezels - Chrome pair
1 Heater Inlet Hose - #10256543
2 Hood Lamp Assembly (GM) - #10203566
1 Hood Lamp Assembly (GM) - Missing Bulb & Cover - #10203566
5 Hood Seal assembly - #10230099
2 Hoses (unknown)
2 Hypertech 160deg. Powerstats
1 Instrument Cluster for 1996 - Stock (used)
2 K&N Filter Care Service Kits
1 Knock Sensor LT1 - AC Delco
1 Lamp Assembly - Trunk - #10268235
2 MAF Outers
1 MAF Sensor - stock - (Center only)
1 Molding - Black - #12522939
1 Molding - Black - #12522934
1 Molding - Black - #12522935
1 Molding - Black - #12522938
1 Molding - Black - #12522932
1 Molding - Black - #12482045
1 Molding - Black - #12482010
1 Molding - Black - #12516867
Nuts / Bolts / Grommets (various)
1 Power Steering Pump Bracket Bolts - #11508202
1 Pulley - Chrome
1 Pulley - Tensioner? Used
4 Quarter Panel Impala SS Script (Black) - #10248742
1 Radiator Hose - lower - #10237350
1 Radiator Hose - upper - #10260864
1 Reservoir Bolt - #11503982
1 Reservoir Float Switch
1 Seal Kit - #17113086
2 Sealing Strip Front - Lower door - #10227341
2 Sealing Strip Rear - Lower door - #10227342
4 Seat Belt Bolts
1 Seat Cover - Front - (OEM perforated gray leather lower)
1 Shift Knob (OEM Black) - #12554714
1 Steering Wheel (OEM Gray - plastic wrapped in box)
1 Sun Visors (DS & PS)
1 Tail Lamp Capsule GM - D/S
1 Tail Lamp Capsule GM - P/S
1 Throttle Cable Linkage bracket - #10192221
1 Tire Iron / Jack Handle - #10190051
1 Trunk Lid Impala Emblem (GM) - #12523079
1 Washer Fluid Reservoir
1 Water Pump
4 Weatherstrip - door surround - #10272731
1 Weatherstrip - trunk lid - #10279815
1 Wheel Opening Molding - Front - #12522936
1 Wheel Opening Molding - Front - #12522937
1 Wheel Opening Molding Kit - Rear Left - #88891404
1 Wheel Opening Molding Kit - Rear Right - #88891403
1 Window Reveal Molding - Rubber/Chrome - Front - #16616524
1 Window Reveal Molding - Rubber/Chrome - Front - #16616525
1 Window Reveal Molding - Rubber/Chrome - Rear - #16615179
1 Window Reveal Molding - Rubber/Chrome - Rear - #16615178
3 Window Switch Rear (GM) Up / Down - #10188907
1 Windshield Washer Reservoir Lower Plug
1 Wiper Arm - #10283600
1 Wiper Arm - #10283601
Thanks.
Roger.
Item
1 Car Bra
4 Fan Shroud Screws
2 Hoses (unknown)
2 MAF Outers
1 Pulley - Chrome
4 Seat Belt Bolts
1 Water Pump
