1 - 12 of 12 Posts
R
Anyone know where to get an in car computer with touch screen anything? Seen a couple but which is best and has most functions.
as far as i know there are no ready made kits to install in a car. what exactly are you looking to do? I'm in the process os building one for my caprice. i started off with a 10.4" touch screen that came with the notebook but i decided not to mold it into the dash and to go with an in-dash vga monitor instead. the only other hard part after that is deciding how you're going to power the pc, via ac-dc inverter or dc-dc power supply. there are many other minor details that you can read about for hours at mp3car.com like shutdown controllers and voice controlled navi software. you can add a usb touch screen to any monitor, check out www.digitalww.com for some ideas, im going with the motorized 7" in-dash vga unit, i had a 7" in-dash tft from them in my last car and it was a good unit at the price i paid. good luck
A
Drive Soft, like the ones they use on Pimp My Ride. So many options that you can choose from.
V
like mike said, mp3car.com is the best site to go
R
i am doing the same thing i have alredy put the a\c in the center console of my car i am puting a 10" screen in the place of the radio and the a\c and where the impala ss is on the dash of the car it will be on the screen as a screen saver big things and big dreams if you do do it the sky is the limit ther is so much that you can do it is crazy
ps: good luck and if you have any ? hit me up
Ok, question. This is something I've done before and plan on doing with my RM. However, one thing I hated was the fact that the dash didn't turn out to great when I did it the first time.
How are you guys going to be fitting them in the dash?
I've been trying to locate a company that will build me a custom dash so I can keep a stock lookiing feel to the car.
R
you will need a barebone screen then you will mold the screen in the dash so that it is one peace with some fiberglass and sand paper it will take some time to do but it can be done
A
ithink i have a small concept of this, but how do you get it to play throught your spekaers? run a amp then rcas from the comp?
I've already got the screen. It's a 7.5" TTF deal. But I know nothing about fiberglass. Plus I wanted a slightly different design that flows smoothly down to the center console.
Can this be done with fiberglass as well? How hard is it to work with?
1 - 12 of 12 Posts
