1 - 10 of 10 Posts
F
ANYONE HAVE THE CLARION VRX745VD? IS THERE A CLEARANCE ISSUE WITH THE UNIT. WHAT IN-DASH MOTORIZED MONOTORS ARE YALL RUNNIN
ive been looknig at that one too. hopefully someone will chime in about it. i like the ipod interface and the touchscreen control. oh, and by the way WHEN YOURE IN ALL CAPS IT MEANS YOURE YELLING!
Do a search, lately i've seen some talk on flip-outs.
K
I have the Pioneer AVX-P7300DVD. There is a clearance issue because of the knobs for the A/C. What I do is, I pop the knobs off everytime I open the radio up. You don't have to do this if you don't want to. Your radio should have a way to adjust the angle of the radio. So, you can have the screen sit straight up and down and keep your knobs on the dash. You have to set your angles just right. If they are not right, then you will wear the gears down fast in the radio. And that means off to the shop. On my radio, I have to take the knobs off so I can see the screen more clearly. So, just take those knobs off and save yourself the trouble. HTH.
F
i got the pioneer flip out
it has adjustment to move screen away or closer to knobs
T
I thinking about getting the ac controls move and throwing in there a kenwood double din
F
i was gonna switch mine
there was no need with the unit i got
but you may like the unit monted on top
K
With my Pioneer unit, when it sits straight up and down, the back of the radio is on the A/C knobs. So, I pop my knobs off. Anything to save those gears in the radio. They will go out eventually, but you can help them from going out prematurely. And with my unit, you can see the screen better with the knobs off, and the screen adjusted farther back.
I work part time at an audio store here in Tucson AZ. AUDIO 2000 and I have the VRX755vd in my ride, no problems at all. even though shortly afterwards i ripped my car apart (nothing OEM in my ride anymore" but the Clarion is a great buy. The VRX745vd and the new VRX755VD dont have That stupid brain to locate under your seat, all you have to do is install the unit it self. all self contained
hey just get that extension. move the AC control to the bottom and the monitor to the top. look cool that way anyways. do a search i've seena few SS around like that. or maybe on cardomain.com
1 - 10 of 10 Posts
