Hello does anyone know how to unlock the pioneer avic n2 to operate navigation and watch movies while the car is moving
O
just have a question for you. Did you hook it up your self or did you have a shop hook it up for you. There is a wire, I think it should be pink,brown,or some odd color that you need to ground out,have it hooked up with you ground wire on the harness, then you should be able to see movies or use your nav,while driving.... if you have any trouble finding the wire go on there web site under tech support.. you should find your answers there.
Hey thanks i found the wire today and it works anohter question how do you get the navigation to work without the disc always in
O
I don't think you can, you will need the disc.
