Loyd Elliot told me in an email today that I will need 30-36 pound injectors.
can any one give me a suggestion? something reliable that is not going to break the bank.
a lot of the old post ive found on here about injectors talk about a Ford red top injector part# M9593BB302 But the post was from like 2010 and the guy mentioned that injector being discontinued in that post.
when I put that part number in Amazon there is injectors that comes up but it’s only like 60 bucks for a set And I’m guessing these probably are not the ones you guys are referring to in those old post
Super Moderator
The real challenge is getting all of the correct characterization data. I have a set of 36lb injectors with full characterization data for half the price of new ones. More info here. If you have a '94-95 or an LS PCM swap, I can help you. If you have a '96, you'll need to find someone with JET DST or a tuner that can update your PCM for you, although if you can wait a few months, I'll be able to help you with the '96 reprogramming.
my car is a 96 but im switching the car to a 411 pcm with coil packs, torqhead kit i think its called. ive been planing and talking about doing this for ever, i finally emailed loyd im pretty excited
