1 - 1 of 1 Posts
Well, I triped on what could be the problem.
I dont think the EQ likes to power two different amps. In an attempt to fix the problem, I tore the dash apart and plugged the rear RCAs into the rear RCA out of the head unit and rewired it to only use the front channel of the amp... All that noise/distortion went away
Bizarre to say the least, the EQ loved powering the single 4channel amp.
Sound is much better now! Eq set to 2 channel, controling the fronts
1 - 1 of 1 Posts
