If it's still higher (1/2") on the drivers side with you sitting in the car, that's not so good. Swap the rear springs and if the passenger side is now a little higher (1/2") that would be good. 1/2" difference can be easily and cheaply offset with AirLift part # 60763. Both sides exactly the same with a little more air (3lbs) in the passenger side AirLift is optimal.
Just installed my hotchkis lowering springs and bilstein shocks on my 96. Now the rear of the car sit uneven. Driver side rear sits a little higher than the passenger side, anyone have an idea what i did wrong?
By any chance did you find a solution for your problem? I have the same springs waiting in my garage for install.
