H
The problem my alarm has is that the unlock works on every door except the drivers door. The issue is supposed to be because the factory keyless entry is "one click to unlock the drivers door, and two clicks to unlock the other doors". With a one wire lock system you are supposed to connect 2 resistors in parrallel to over come this. Problem is that our cars are 2 wire systems. Has anyone else had this problem and over come it?
J
IIRC you need to tap into the wires from the drivers door lock/unlock button not the wires going to the solenoids. this will allow the stock control box to operate all the doors at once.
John
I've never had any probplems w/ the locks in these cars.
White = unlock
Lt Blue = lock
Tap in the D/ kick panel, and be done.
BTW, what alarm are you using?
