My int lights only come on from the dash switch. None of the doors will activate it. What is the common cause and fix of this?
Also if I put the twilight sentinal switch on, and leave it on, it will run down the battery. Is this problem in the switch itself, or the module in the pass kick panel?
Thank you
Bill
The courtesy light relay. It is located in the convenience center under the dash, by the steering column. I recentlly saw a post that stated the black relay on the left is the courtesy light relay.
The relay was missing. I went out and got one and now it works.
I still need to find out why the twilight sentinal drains the battery down if left in the on position.:confused: I think it is in the module in the kick panel, but not totaly sure.
My guess would also be the box in the RH kick panel.
Steve
Steve
You got another known good one for sale? The last one you sold me for the wagon did the trick with that issue.
