this is on my 95 Roady I just picked up. IT had a fuel problem and some other things making it not run, but once I got the fuel pump fixed in it, I jumpered the connector on the passenger fender to prime the pump and within the intake I can hear a hissing/gurgling almost. just curious if anyone else has ever heard/seen this. I am guessing maybe a stuck injector or pressure regulator, but the fuel pressure is good and according to the values in the FSM. It starts fine and idles great, but if you blip the throttle it bogs, but then clears out, any advice or if you heard this before would be appreciated, thanks.
