ok so im new to the forum ive looked at other threads and i cant seem to get a straight answer.
i checked all the fuses their all good. im done like wiggle tested on wires and tapped on the dashboard. nothing my hvac isnt lit up nor is the cluster backlights and the digital dash doesnt work either.... i dont know what to check next.
ok following GM diagnostics found the dimmer module (not switch) has an internal short. replaced it now working fine.
also fixed power door locks found driver door switch sticking to lock (internal short) replaced. working properly keyless entry and all.
Thanks for ALL THE RESPONSES AND HELP GUYS!
